Is it possible to post data to a resources field using a custom script
Good day,
Is it possible to get data from an additional field and then post the data to a resource question field in the same template. Using a custom script.
I have found the following script command on the ME documentation:
$CS.setValue("RES_3_QUS_3", ["CD RW", "External Harddisk", "Optical Mouse"]); as an example.
I can not identify the resouces questions UDF field id's as query reports is disabled in SDP cloud.
https://pitstop.manageengine.com/portal/en/kb/articles/service-catalog-resource-questions
The only suppported way to identify the resources question id's
Thanks
Regards
