SWITCH 6509 - PROBLEMS TO SET THRESHOLD TEMPERATURE FOR INTERNAL MODULES
Dear Sirs.
can you help me with the next problem, please?
we are using OPManager to monitor a switch 6509 cisco temperature.
we can see the temperature of each module, for example Module 6-asic 8, but when we select the option EDIT to modify independently each module appear the message:
MESSAGE FROM LOCALHOST PAGE: 9090
ENTER THE SNMP OID
The selected module 6 asic-8 shows as SNMP OID: .1.3.6.1.4.1.9.9.13.1.3.1.3.60069
We have added this snmp oid in the template of 6509 switch but again appears the same mesagge when we try to modify the temperature of this module.
Thanking you in advance.
