Problem with approvals triggers after apply 3917
Hi
Any body use triggers for approvals automation?
I have several that work fine before apply sd+ 3917+ update. ( py scripts)
After this don´t work and i don´t have any reason.
The request history tab has changed and now does not report anything. The trigger does run,
I can not find error trace except for a java type conversion warning when I go to record in the history table.
Is there anyone who does the same?
JCF
