problem running reports SD+ 6
hi
i have just upgraded from 5.5 to version 6 and i am no longer able to run reports
when i go to the report section and click on a report to run it, it says no data available
when i modify the report and go thru all the steps basically when i click on run report nothing at all happens,
this is quite irritating as i use the report function a lot
has anyone else had this issue and or knows of a solution?
thanks
