problem monitoring localhost (where opmanager is installed)
I got this error:
User credentials cannot be used for local connections
Following this tip doesn't work:
There are 2 problems:
1. After I removed the windows credential, I can no longer add any new wmi monitors. I get error message saying I need to supply username and password.
2. I cannot use device template
I found a work around by specifying a dummy username/password. However, it doesn't address the device template issue.
Also, where do I download the latest update patch for OpManager?
