Power settings not deploying properly.
I am playing around and testing with the power scheme settings available in Desktop Central.
I deployed a scheme that basically has the Shutdown button set to power off the test unit when the button is pressed, as well as when sleep button is pressed.
I verified the test laptop's power settings to see if they changed.
The correct scheme name was deployed and set active, but everything seems to be set to default - everything is set to "SLEEP" for the button presses.
Currently using the newest build: 80251
Netagent installed - 8.2.50.W
System is on the local network, hardwired (wireless disabled on this unit)
Let me know if there is anything else I can provide.
See images bellow
Configuration
Result after deployment to test laptop
Senior Client Technology Support Analyst
Bird Construction Inc
http://www.bird.ca
http://ca.linkedin.com/pub/carlo-piva/31/267/a5b
