Monitoring MS SQL servers (AppManager running 2008 R2 64-bit)
Should this be working? We can't seem to add MS SQL monitors (tried both SQL 2008 and SQL2000)
What is frustrating is that when we try to add the monitor, the page loads for about 30 seconds and then just refreshes without any confirmation/error/warning. Very frustrating as we have nothing to troubleshoot with.
We tried both sa and normal sysadmin account to rule out any permissions issues.
Adding ODBC from the AppManager server to the database servers works like a charm.
Any ideas? Also are there any logs in cause a monitor fails to be installed? I have seen this in other cases also (the page just refreshes without any information whatsoever)
