Monitor script not working on UTM/Linux system
Hi guys,
I have several UTMs that are linux based, and I got a bunch of scripts that need to be run on those.
Thus, I wrote a simple one, tested on a Debian (worked) via ssh/putty and via OpManager, but when testing on the UTM it worked
via ssh using putty
, but via OpManager it didn't.
Note: on both I got the password/credentials test working.
Note2: I takes aprox. 20 seconds to return the error (However it is not by timeout):
| Exit Code |
4 |
| Message |
Script_teste:Internal Server Error while processing this request. |
| Data |
Data is not found/invalid data format - Please refer the help card 'Output Format' part for assistance. |
| Raw Output |
Here is the script:
| Execute From |
Local Server Monitored Machine |
=============BEGINNING =======================
UTILIZATION=`df -h /var/log | tail -n 1 | tr -s " " | awk -F " " '{print $5}' | tr -d "%"`
echo Message: /var/log utilization "$
UTILIZATION"%
echo Data:
echo -e "
Utilization\t$
UTILIZATION"
exit 0
=============END =======================
Thanks.
