Java 32 bit and 64 bit versions are not being patched automatically
hi guys
i have a dilema where i have machines with both versions of Java. 64bit is showing up as needing a patch and gets patched however 32bit is not showing as needing a patch even tho there is a new version available just as the 64bit version. I am told that Desktop Central if it sees both versions it can only patch the 64bit version. Has any of you seen this, any reason why it cannot patch both? Obviously we can do a manual deployment but it would be easier if it was to see the required patch and deploy it.
Thanks
