[SOLVED] Help with Script to double costs based on field option greater than 1
Can anyone help me create a script to execute on field change. That if the entry is greater than 1 then the costs will multiple by that number. Example: If the total cost is $15,000 and they choose that they need 2 then I need the total cost to reflect 2 @ at price of $30,000.
