Catci SMNP vs Manage Engine Netflow – Approx 8 to 10% difference data readings.
Hi guys is there any way to tweak the total amount of inbound + out bound data Manage Engine Netflow displays for a IP group over "x" amount of time.
When I compare netflow results with catci, netflow is under reading slightly.
Whilst I believe the netflow figure might be actually correct, is there to manually adjust up (or down) the value displayed within manage engine netflow.
Ie add 10% to all the values show / stored within manage engine netflow so I can have both our netflow system and catci system display almost perfectly the same.
Thanks V22.
