Automation data from MS SQL "Ignore current records in DB" greyed out/not working?
I'm having an problem with importing users from an SQL db into our AD.
The first import from the SQL db is ok. But when I run it an second time then I get the error that the object already exists. Why is it doing the same users again? Is this expected behaviour?
There is an option by the "Create New Automation" where you have the option to add an marker to the option "Ignore current records in DB". But when I use that option then nothing is getting imported from the SQL db. The job result is always "No input detected at the data source".
Also there is no option to remove the marker after you have saved it.
I'm using the demo version (build 7030) from ADmanager on an Windows 2019 server with an local SQL 2017 developer edition.
Michel
