Auto login problems and layout question
When using auto login and setting up resources, I am having problem using it with ACT Premium for Web. The system uses .aspx files. The login page is:
Username/password
Chris Huffman/<blank>
How can I setup the resource url?
Also, is there a way to customize the UI more than what is found in the Admin tools?
Karim
