After enabling SSL on ADSelfService, Single Sign On does not work and asks for credentials....
We have ADSelfService work with single-sign-on on HTTP without any issues. I decided to purchase a SSL certificate and assign an external domain to the server in order to have it accessible from the internet. After the wonderful help from MangeEngine support, I was able to get SSL working on the site with the port 9251. Now the issue is that when I access the site from any computer internally, the single sign on does not work any more and I get prompted to enter my domain credentials before been able to access the site.
Did anyone experience the same issue. The SSL certificate is a simple certificate with one domain and is valid. But the internal domain is different than the website domain, would that cause a problem and if so is there a way to tell the webserver to change that or use something else? Sorry I am not sure how that works... Maybe there is a permission issue with the site files?
Thanks for your help!
