Upcoming enhancements in Requests,Problems,Changes,Notification Rules,Project,Triggers,Sandbox and Zia
Dear Users,
We are elated to announce the upcoming enhancements in Requests,Problems,Changes,Notification Rules,Project,Triggers,Sandbox and Zia .Below is a brief run-through of the same:
Requests
Request Closure Rules Enhancement
The UI for Request closure rules has been revamped for better user experience. Now if the mandated tasks, worklogs, checklists, and linked requests are not processed before request closure, an error message will be shown in the pop-up form.
Problems
Problem Enhancements
Create a resolution template with all necessary details that need to be updated along with resolution or workaround to guide other technicians.
Introducing a dedicated view Known Errors for technicians to filter problems with the Known Error tag.
Generate reports based on known error and known error comments
Differentiate notifications triggered via problem life cycle, triggers, etc., by checking the History tab in the problem details page.
Users can now choose to view the number of changes associated with problems as a column in the problem list view if needed.
Technicians can send notifications to Users, Problem Users, and Organization Roles using Send Notification pop up under Actions > Send Notifications in the problem details page.
Technicians of associated requests will be auto-populated in the To field while notifying the incident technicians using the Actions menu in the problem details page.
Requesters of associated requests will be auto-populated in the To field while notifying incident requesters using the Actions in the problem details page.
Technicians can now initiate announcements with newly added problem values such as impact details, root cause, and symptoms under Actions > Make an announcement in the problem details page.
Admins can now mandate impact details, symptoms, and workaround details while closing a problem using Problem Closure Rules.
Admins can now mandate request association to a problem via problem closure rules.
Technicians can create new problems using templates other than the default template from problem list view.
Changes
Associate Projects with Change
Associations tab is introduced in the Change Submission stage to associate project that initiated the change.
You can now associate a project that initiated the change in the change submission stage and multiple projects caused by change in the change implementation stage.
Notifications Rules Enhancements
The notification rule Notify change owner when an associated project is closed or canceled is now modified to Notify Change Owner when a project that is initiated by a change is closed or canceled. The change owner will now be notified only when a project initiated by a change is closed or canceled.
Setup
      Sandbox Enhancements
      Zia Chatbot Customization
      System Log Enhancement
       Triggers and Custom Actions Enhancements
For more information , Kindly refer to https://www.manageengine.com/products/service-desk/cloud/pre-release-notes.html
Ramyaa Raj
