Upcoming enhancements in Problem, Reports
We are elated to announce the upcoming enhancements in Problem, Reports  .Below is a brief run-through of the same:
Problem Enhancements
  • You can now create a solution or workaround specific to a problem and add it to Solutions using Save and Add to Solutions.
  • Added options to copy and associate a solution or workaround from the solution database to the Problem Solution.
  • Technicians can now use closure codes while closing a problem. SDAdmins can configure closure codes under Setup > Customization > Problem Management > Closure Code.
  • You can now associate multiple changes to a problem.
  • Added option under problem closure rules to mandate association of a change to a problem.
  • The closed state of a problem is now conveyed by a stamp on the right panel of the problem details page.
  • The Mark as Known Error option is now available in the Actions drop down if the value of Known Error is No.
  • New notification rules are added under Setup > Automation > Notification Rules > Problem.
    • Notify group members when a new problem is assigned to their group.
    • Notify technician when a new response is received.
    • Email users when a note is added to the problem.
  • You can now send email notification to org roles (Reporting Manager) and users (Reported By, Technician) associated with the problem.
  • The UI text for problem notification rules Notify to incident technician/requester is now modified as Send Notification for Problem for better user understanding.
Reports
  • Problem reports now support the Closure Code and Closure Comments fields.
  • Solution reports now support the Associated Problem ID, Associated Problem Title, and Associated Problem Type fields.
For more information, Kindly refer to https://www.manageengine.com/products/service-desk/cloud/pre-release-notes.html
