Unable to start Manage Engine - help
Hello Sir,
We are using Manage Engine Application Manage Engine 9.2 Trial version, installed in windows 2003.
Problem:
The trial version was working fine for say 3 or 4 days. But now we have problems in starting the application. The following exception is seen in start up log.
 Exception while executing mysqladmin command to create database. Please check the executable and permissions
java.io.IOException: CreateProcess: G:\Program Files \ManageEngine\AppManager9\working\.\mysql/bin/mysqladmin -u root --password=appmanager --port=13344 -h localhost create AMDB error=193
Can someone please provide solution ASAP.
