[SD-102719] Strange problem with integration between ServiceDesk Plus and Desktop Central
Hi
We are running the latest SDP and DesktopCentral versions (13002 and 10.1.2138.15). Our integration is working and is ok according to the tests.
However, when trying to use the "Desktop Central" menu it downloads a file "softwarenames.txt". This was working before updating SDP to 13002.
Any ideas? I have removed integrations and added it again with new keys. No difference. MDM integrations works (same install as the desktop central) and everything else.
