Small problem with Exchange 2000/2003 add-on monitor
I recently bought the add-on for exchange monitoring and added on my exchange server using the procedure below
1. Go to the snapshot page of the device running Exchange Service.
2. Click Add Monitor option against Application Monitors column in the snapshot page.
3. Click MSExchange 2000/2003 Monitors (WMI Based) from the list.
4. Select the required services and parameters and click Add.
It worked quite fine ... however after a few mins, an alarm was raised
"MS Exchange Event Service, MS Exchange Site Replication Store, MS Exchange POP3 Services are Down "
I disabled those services myself so I wanted to remove them from the monitoring but since then ... I'm unable to get in
All I see is the following image :)
So if anyone can help me out with this :)
