Sender contains and Sender does not contain at the same time
I have an existing "Sender Contains" rule in the Notification filter. I need to add a "Sender Does not contain" rule to stop notifications outside of our domain. When I add the "Sender Does not contain" rule it replaces the "Sender Contains" instead of adding it as a second rule.
Is this normal and if so is there any other way to get the desired result?
MM
