Remote Script Monitor problem
When setting up a remote script monitor, I'm having some issues...
- ssh connection is not working. I can't create the monitor because AppManager can't connect. SSL key issue maybe?
- using telnet, it can connect and create the monitor, but it does not run automatically. When clicking Edit then Save, it suddenly says it can't connect, and to "check host settings". Host settings are inaccessible.
- How do I remove and/or edit hosts from the Remote Scripts host drop-down?
Very frustrating.
Thanks a lot,
--Bob
Bob Burgess
