Remote Desktop Connection Problems.
I have tried everything to get this to connect. Put in ports into the firewall 6100 and 8021. I also even put my IE to LOW and turned off the firewall.
When I try to connect it brings up the blue screen and then says "failed to connect"?
Any suggestions would help.
I am able to push things to this client.
Ed.
