Problem with WAN RTT Monitor
I'm running a trial of your OpManager build 8005. I'm trying to setup the WAN RTT Monitor, I've setup the write communitry string on both router and opmanager to be the same, but when I try to add the router it keeps on saying "SNMP write comunnity maybe wrong"..
So I proceeded in doing the added recommended commands which is "snmp-server host <opmanager server IP> traps <host community string> rtr" into my router.
It says I've succesfully submitted to the device, but when i check the configuration history it still show configuration status "not configured".
Hope you can help.
