problem with snmp device & flexible netflow with nbar
I want to test cisco's flexible netflow with nbar support, but I have problem adding snmp device to Netflow Analyzer.
I enabled snmp debuging on CSR1000v (virtual cisco router) and I see "successfull snmp pooling":
  1. *Dec 19 22:19:41.030: SNMP: Packet received via UDP from 192.168.47.1 on GigabitEthernet1
  2. *Dec 19 22:19:41.030: SNMP: Get request, reqid 49, errstat 0, erridx 0
  3.  system.1.0 = NULL TYPE/VALUESrDoSnmp: received get pdu
  4. CheckClassMIBView: all included
  5. CheckMIBView: OID is in MIB view.
  6. *Dec 19 22:19:41.031: SNMP: Response, reqid 49, errstat 0, erridx 0
  7.  system.1.0 = Cisco IOS Software, CSR1000V Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(2)S2, RELEASE SOFTWARE (fc4)
  8. *Dec 19 22:19:41.032: SNMP: Packet sent via UDP to 192.168.47.1
  9. *Dec 19 22:19:50.129: SNMP: Packet received via UDP from 192.168.47.1 on GigabitEthernet1
  10. *Dec 19 22:19:50.129: SNMP: Get request, reqid 50, errstat 0, erridx 0
  11.  system.2.0 = NULL TYPE/VALUESrDoSnmp: received get pdu
  12. CheckClassMIBView: all included
  13. CheckMIBView: OID is in MIB view.
  14. *Dec 19 22:19:50.130: SNMP: Response, reqid 50, errstat 0, erridx 0
  15.  system.2.0 = products.1537
  16. *Dec 19 22:19:50.132: SNMP: Packet sent via UDP to 192.168.47.1
  17. *Dec 19 22:19:50.135: SNMP: Packet received via UDP from 192.168.47.1 on GigabitEthernet1
  18. *Dec 19 22:19:50.135: SNMP: Get request, reqid 51, errstat 0, erridx 0
but device is not added - it's stuck "INPROGRESS"
Any ideas what could be the problem? And how do I delete devices? In inventory I see 'edit' button, but it's just for editing names. Device is actually added if I understand correctly, I see interface speed, some data, I also see netflow datas, but without layer7 (nbar) support:
