Problem with Actions using Script
Hi Team,
I'm having troubles setting approvers throught scripts using a python file named "python_approver1.py"
This is te code of  "python_approver1.py":
SETTING APPROVALS FOR THE CURRENT STAGE:
 "operation": [
 "INPUT_DATA": [
 "aabarca@ulacit.ac.cr"
 "OPERATIONNAME": "ADD_APPROVAL"
 "message": "Sample Python script for adding approvals in current stage",
 "result": "success"
This file is in the following directory: C:\ManageEngine\ServiceDesk\integration\custom_scripts
In the attached named "captura.png" I put the setting action in the SDP. But when I try to test making tickects I got this issue in the attached named "captura2.png"
Would you help me with this issue
