Problem using DistributionServer
I'm testing Desktop Central. The Local Office works fine, reports, softwaredistribution and so on are OK.
Now I installed an DS to distribute software in the other locations.
A lot of data syncronices to the DS (/replication\client-data\patch-scan-data an some other), an Inventory scan works fine for Local an Remote Office Computers, so the communication Server <--> DS works.
But I'am not able to distribute software.
I created a testjob with 4 Computers, 2 in the Local office, 2 in the WAN. The Local-Office Computers are installes, the Computers in the WAN are "Yet to applied" an no installation starts (Waitung, Reboot Computer dont help).
I look some houres in the logs on the DS an Server. What i saw ist that sometimes are errors in the
dcdsreplication.log
TestNP is the testsoftware to distribute (Name of the configuration file). The errormessage ist "Cant find the file"
[ 2010-12-16 16:05:43 ] [ 3864 ] ChangeUtf8ToWideStr: utf8 is empty!
[ 2010-12-16 16:05:43 ] [ 3864 ] InternetGetRequestByBitrate : DesktopCentral Server & Port -> 10.233.15.21 : 8020
[ 2010-12-16 16:05:43 ] [ 3864 ] InternetGetRequestByBitrate : Content Length of the request file: 744 Bytes
[ 2010-12-16 16:05:44 ] [ 3864 ] InternetGetRequestByBitrate: Total bytes readed = 744
[ 2010-12-16 16:05:44 ] [ 3864 ] Message : Der Vorgang wurde erfolgreich beendet.
 [ 2010-12-16 16:05:44 ] [ 3864 ] AgentSendRequest : Last Access Address is 10.233.15.21
[ 2010-12-16 16:05:44 ] [ 3864 ] ProcessCollections : ********* Collection Started for collectionID : 301 and Name : TestNP *********
[ 2010-12-16 16:05:44 ] [ 3864 ] Error Code : 2 , Error Message : Das System kann die angegebene Datei nicht finden.
Sometimes i get the Error 404 from the Desctop Central Web Server
 2010-12-16 16:17:50 ] [ 420 ]  @@@@@@@@@@@@ Inside InternetDownloadFileIfmodifiedSince method @@@@@@@@@@@@@
[ 2010-12-16 16:17:50 ] [ 420 ] AgentSendRequest : The url to get / send in UTF8 format is given by client-data/1/master-meta-data.xml
[ 2010-12-16 16:17:50 ] [ 420 ] ChangeUtf8ToWideStr: utf8 is empty!
[ 2010-12-16 16:17:50 ] [ 420 ] InternetGetRequestByBitrate : DesktopCentral Server & Port -> 10.233.15.21 : 8020
[ 2010-12-16 16:17:50 ] [ 420 ] InternetGetRequestByBitrate : File not modified since the time: Thu, 16 Dec 2010 15:14:54 GMT
[ 2010-12-16 16:17:50 ] [ 420 ] InternetGetRequestByBitrate: Total bytes readed = 0
[ 2010-12-16 16:17:50 ] [ 420 ] AgentSendRequest : Last Access Address is 10.233.15.21
[ 2010-12-16 16:17:50 ] [ 420 ] Message : Der Vorgang wurde erfolgreich beendet.
 [ 2010-12-16 16:17:50 ] [ 420 ]  @@@@@@@@@@@@ End of InternetDownloadFileIfmodifiedSince method @@@@@@@@@@@@@
[ 2010-12-16 16:17:50 ] [ 420 ] @@@@@@@@@@@@@@@@@@ Inside ProcessMAMetaData @@@@@@@@@@@@@@@@@@@@@@@
[ 2010-12-16 16:17:50 ] [ 420 ] ***************Checking master agent version********************
[ 2010-12-16 16:17:50 ] [ 420 ] @@@@@@@@@@@@ Inside isMAUpgradeRequired Method  @@@@@@@@@@@
[ 2010-12-16 16:17:50 ] [ 420 ] isMAUpgradeRequired: is DS license valid: 1
 [ 2010-12-16 16:17:50 ] [ 420 ] @@@@@@@@@@@@ End of isMAUpgradeRequired Method  @@@@@@@@@@@
[ 2010-12-16 16:17:50 ] [ 420 ] @@@@@@@@@      Inside GetRemoteOfficeXML @@@@@@@@@@@@@@@
[ 2010-12-16 16:17:50 ] [ 420 ] @@@@@@@@@      End of GetRemoteOfficeXML @@@@@@@@@@@@@@@
[ 2010-12-16 16:17:50 ] [ 420 ]  @@@@@@@@@@@@ Inside InternetDownloadFileIfmodifiedSince method @@@@@@@@@@@@@
[ 2010-12-16 16:17:50 ] [ 420 ] AgentSendRequest : The url to get / send in UTF8 format is given by client-data/1/ds-data/dcreplication.vbs
[ 2010-12-16 16:17:50 ] [ 420 ] InternetGetRequestByBitrate : Failed with the http status code: 404
[ 2010-12-16 16:17:50 ] [ 420 ]  Error Message: Falscher Parameter.
Someone an Idea to get Software installes on the Remote Office PC's ???
Thanks in advaced
