Problem Running Powershell in Notification Profiles
Hello, i have an issue with notification profiles.
I have created a "Run system command" notification profile, that failed. Bellow i detail the configuration of the notification profile:
Command String: powershell.exe -c "E:\scripts\EnviaCorreo.ps1"
When i push the test button, it appears "Command Executed Sucessfully", in the task manager of the opmanager server the process powershell.exe is executed, but the script isn´t executed.
The scripts works propertly if i execute it from the command line of the server.
Can anybody help me?
Thanks.
