problem monitoring localhost (where opmanager is installed)
I got this error:   User credentials cannot be used for local connections
Following this tip doesn't work:
http://www.manageengine.com/network-monitoring/help/troubleshoot_opmanager/troubleshoot_wmi.html#80041064
There are 2 problems:
1.  After I removed the windows credential, I can no longer add any new wmi monitors.  I get error message saying I need to supply username and password.
2.  I cannot use device template
I found a work around by specifying a dummy username/password.  However, it doesn't address the device template issue.
Also, where do I download the latest update patch for OpManager?
