Problem ManageEngine running OpUtils 4
I downloaded install exe.
Installation was successful.
I Installed Service.
I start program from Start / Programs.
I see cmd window (probably starting the service).
I see the blue pop-up splash window.
Then nothing.
I see icon in sys tray with a red "x" in lower right corner.
I also sent support file to you which supposedly had the zip file of the event logs.
Can you help?
Thanks.
Denis Grau
