Problem in Auto discovery feature in our NMS Web application
Hi All,
             I need a help on this .
Problem:  In our application there is auto discovery feature, in that we can discover the  SNMP agent in three ways
               a)   Local Network--It will constructs  PDU and broadcast packets  into Broadcast IP. (192.168.6.255 in our case)
               b)   Entire Network--It will check nodes in entire network
               c)   Select Range--We need to specify the IP range to detect nodes
   We have device i.e media converter  which has IP:192.168.6.166. This device detected in b) & c) approach ... but could not able to locate in a)  approach .
      I have attached the core code here ... Please help me to overcome this problem.
public class AutoDiscovery implements SnmpClient {
public synchronized void getNetworkElements(String action) {
                   System.out.println("inside getNetworkElements");
        try {
            try {
                String deleDiscovery = "DELETE FROM TblAutoDiscovery";
                   dbCon.executeSql(deleDiscovery);
            }catch(Exception e4) {
                appLogger.logError("Exception in Deleting from TblAutoDiscovery"+e4);
            try {
                String deleDiscoveryDetails = "DELETE FROM TblAutoDiscoveryDetails";
                dbCon.executeSql(deleDiscoveryDetails);
            }catch(Exception e8){
                appLogger.logError("Exception in Deleting from TblAutoDiscoveryDetails"+e8);
            String values[] = {
                                "None", null, null, "161", null, null, "None",
                                null, null, null, null, null, null, null,
            AutoDiscoveryGenerics ADG = new AutoDiscoveryGenerics();
            String serverip = ADG.NMSServerIp();
            System.out.println("SERVER IP---->"+serverip);
            System.out.println("----------------");
            String strIpWildcard = serverip.substring( 0,serverip.lastIndexOf(".") );
            String IP4 = "255";
            String broadcastIP = strIpWildcard + "." + IP4 ; //Broadcast ip calculation Algorithm has not been done worked out with serverip(99.9% perfect)
            System.out.println("bROADCAST IP---->"+broadcastIP);
            System.out.println("-------------");
            AutoDiscovery snmpobj = new AutoDiscovery ();
            //Start SNMP API
            snmpobj.api = new SnmpAPI();
            if (values[0].equals("Set")) {
                System.out.println("inside set");
                snmpobj.api.setDebug( true );
            // Open session
               snmpobj.session = new SnmpSession(snmpobj.api);
            int PORT = 3;
            SnmpPDU pdu = new SnmpPDU();
            UDPProtocolOptions ses_opt = new UDPProtocolOptions();
            pdu.setVersion(SnmpAPI.SNMP_VERSION_2C);
            ses_opt.setRemoteHost(broadcastIP);
            if(values[PORT] != null) {
                System.out.println("inside if");
                System.out.println("--------------");
                try {
                    ses_opt.setRemotePort(Integer.parseInt(values[PORT]));
                }catch(Exception exp) {
                    System.exit(1); //Has to be Tested
            pdu.setProtocolOptions(ses_opt);
            snmpobj.session.addSnmpClient(snmpobj);
            // Build Get request PDU
            pdu.setCommand( snmpobj.api.GET_REQ_MSG );
            // add OIDs (Multiple OIDs)
            Vector remaining = new Vector();
            remaining.addElement(Constants.OID_SYSTEM_DESC);
            remaining.addElement(Constants.OID_IPFORWARD);
               remArgs = new String[remaining.size()];
            for (i=0;i < remaining.size();i++) {
                System.out.println("inside first for loop");
                remArgs[i] = (String) remaining.elementAt(i);
                System.out.println("remaining arguments------>"+remArgs[i]);
                for (int i=0;i < remArgs.length;i++) {
                System.out.println("inside second for loop");
                SnmpOID oid = new SnmpOID(remArgs[i]);
                if (oid.toValue() == null) {
                    System.out.println("if oid is null");
                    appLogger.logSNMPError("Invalid OID argument: " + remArgs[i]);
                } else {
                    System.out.println("if oid is not null");
                    pdu.addNull(oid);
            System.out.println("after for loop");
               pdu.setTimeout(10000);
            try {
                //Open session
                System.out.println("sesion is opened");
                snmpobj.session.open();
            }catch (SnmpException e) {
                appLogger.logSNMPError("Error opening session:"+e.getMessage());
            try {
                //snmpobj.session.send(pdu);
              //e.printStackTrace();
              appLogger.logSNMPError("Error sending pdu:"+e);
               String[] ip_ListOfSwitches =  new String[1] ;
               int j = 0;
            while(true) {
                System.out.println("inside while true");
                try {
                    Thread.sleep(1000);  //old value 100
                }catch(Exception e) {  }
                if (snmpobj.getFinished && action.equals("ViewAutoDiscoveryLocal")) {
                    break;
                if(snmpobj.getFinished && !action.equals("ViewAutoDiscoveryLocal")) {
                    if(snmpobj.check2){
                        String[] ip_ipForwardNextHop =  new String[10] ;
                        int j1 = 0;
                        Vector finalhopList = getNextHops(strIpWildcard + "." + "1");
                        Iterator it1 = finalhopList.iterator();
                        while(it1.hasNext()) {
                            ip_ipForwardNextHop[j1] =  it1.next().toString();
                                  checkipForwardAndAddToDb(ip_ipForwardNextHop[j1]);
                            j1++;
                    Vector v  = getListOfSwitches();
                    ip_ListOfSwitches = new String[v.size()];
                    Iterator it = v.iterator();
                    while(it.hasNext()) {
                        String walkedData1[] = new String[1];
                        ip_ListOfSwitches[j] =  it.next().toString();
                        SNMPRequest snmpw = new SNMPRequest();
                        String oidwalk[] = new String[1];
                        oidwalk[0] = Constants.OID_IPADENTADDR;
                        String oidwalk1[] = new String[1];
                        oidwalk1[0] = Constants.OID_IPNETTOMEDIANETADDRESS;
                        try {
                            for( int k = 0; k < ip_ListOfSwitches.length; k++ ) {  //get the ipNetTo Madia for the subnets in the switches
                                walkedData1 = snmpw.snmpWalk(oidwalk1, ip_ListOfSwitches[k]);
                        }catch (Exception EX) { }
                        try {
                            for( int k1 = 0; k1 < walkedData1.length; k1++ ) {
                                String strIpWildcard1 = walkedData1[k1].substring( 0,walkedData1[k1].lastIndexOf(".") );
                                for( int k22 = 0; k22 < ip_ListOfSwitches.length; k22++ ) {
                                    String strIpWildcard12 = ip_ListOfSwitches[k22].substring( 0,ip_ListOfSwitches[k22].lastIndexOf(".") );
                                    if(strIpWildcard1.equals(strIpWildcard12)) {
                                        pollAndUpdate(walkedData1[k1]);
                         }catch (Exception e) { }
                          j++;
                    break;
               } //End of Outer while
            appLogger.logError("Exception in AutoDiscovery.java - getNetworkElements(): "+ e);
   public boolean authenticate(SnmpPDU pdu, String community) {
       System.out.println("inside authethentication>>>>>>>>>>>>>>"+pdu.getVersion());
           if(pdu.getVersion() == 3) {
            return !((Snmp3Message)pdu.getMsg()).isAuthenticationFailed();
        } else {
            return (pdu.getCommunity().equals(community));
   private int totalResponses = 1;
     * Callback method that is invoked on receiving an SNMP Inform request message
   public boolean callback(SnmpSession session,SnmpPDU pdu, int requestID) {
       System.out.println("inside callback");
           // Check if valid PDU
        if (pdu == null) {
            System.out.println("inside if condition where pdu is null");
           //System.out.println("Null PDU received:Timeout\n");
           getFinished = true;
           check2 = true;
        } else {
            System.out.println("inside else part where pdu is not null");
            String res =  pdu.getProtocolOptions().getSessionId() + ".";
            UDPProtocolOptions opt = (UDPProtocolOptions)pdu.getProtocolOptions();
            String remoteHost = opt.getRemoteHost();
                System.out.println("inside get version if loop");
                res = res + " Community: " + pdu.getCommunity();
            // print varbinds
            Enumeration e = pdu.getVariableBindings().elements();
            boolean check = true;
            boolean check1 = true;
            while(e.hasMoreElements()) {
                String theReqObject = ((SnmpVarBind) e.nextElement()).toTagString();
                String ip = pdu.getVariable(1).toString();
                System.out.println("before try block");
                   try {
                       System.out.println("inside try block");
                    if(check1) {
                           check1 = false;
                        if(ip.equals("1")) {
                            String insQry1 = "INSERT INTO TblAutoDiscoveryDetails (IPAddress,IpForward) Values ( '"+remoteHost+"','"+ip+"' );";
                            dbCon.executeSql(insQry1);
                   }catch(Exception e7){ //e7.printStackTrace();
                    try {
                         String sysDes = pdu.getVariable(0).toString();
                         System.out.println("--0---"+pdu.getVariable(0).toString());
                    System.out.println("---1--"+pdu.getVariable(1).toString());
                    System.out.println("SYSdES===>"+sysDes);
                         SystemDescription SysDescr = new SystemDescription(sysDes);
                         String sysD = SysDescr.getSystemDescription();
                         System.out.println("getSystemDescription from SystemDescription===>"+sysD);
                    int iNodeID=0, iNoOfFxPorts=0, iNoOfUtpPorts=0, iFxDistance=0;
                    String strProductName="", strFamilyName = "", strFxSignal = "", strFxConnectorType = "", strFxModeType = "";
                    String strWavelengthType = "", strUtpSignal = "", strBoardType = "", strPowerSupply = "", strOthers = "";
                    String strSysDescr = "";
                         if(check) {
                          check = false;
                        if( sysDes.equals(sysD) ) {
                            System.out.println("System Descriptions are euual");
                            String productFamilyName = SysDescr.getProductFamilyName();
                            int productType = SysDescr.getProductType();
                            int noOfFxPorts = SysDescr.getNoOfFxPorts();
                            int noOfUtpPorts = SysDescr.getNoOfUtpPorts();
                            strProductName = SysDescr.getProductName();
                            System.out.println("Product name from System Description");
                            if( strProductName.equals( Constants.PRODUCT_NAME[ Constants.PRODUCT_TYPE_IVY2424 ] ) ){
                                iProductType = Constants.PRODUCT_TYPE_IVY2424;
                            } else if(strProductName.equals(Constants.PRODUCT_NAME[Constants.PRODUCT_TYPE_FCAT100M])){
                                iProductType = Constants.PRODUCT_TYPE_FCAT100M;
                                GetDetails liteviewDetails = new GetDetails();
                                String[] productStatus = liteviewDetails.getProductDetails( iProductType );
                                if( productStatus != null && !productStatus[0].equals( Constants.NO_DATA )
                            && Integer.parseInt( productStatus[2] ) == Constants.PRODUCT_ACTIVATED ) {
                                strSysDescr         = SysDescr.getSystemDescription();
                                strFamilyName         = SysDescr.getProductFamilyName();
                                iNoOfFxPorts         = SysDescr.getNoOfFxPorts();
                                strFxSignal            = SysDescr.getFxSignal();
                                strFxConnectorType     = SysDescr.getFxConnectorType();
                                strFxModeType         = SysDescr.getFxModeType();
                                strWavelengthType     = SysDescr.getFxWavelengthType();
                                iFxDistance         = SysDescr.getFxDistance();
                                iNoOfUtpPorts         = SysDescr.getNoOfUtpPorts();
                                strUtpSignal         = SysDescr.getUtpSignal();
                                strBoardType         = SysDescr.getBoardType();
                                strPowerSupply         = SysDescr.getPowerSupply();
                                strOthers             = SysDescr.getOthers();
                            System.out.println("BEFORE INSERTING INTO TblAutoDiscovery");
                            strSql = strSql.delete(0, strSql.length());
                            strSql = strSql.append("INSERT INTO TblAutoDiscovery ( IPAddress, SystemDescription, ProductFamilyName, ");
                            strSql = strSql.append(" ProductType, NoOfFXPorts, FxSignal, FXConnectorType, NoOfUTPPorts, UTPSignal, ");
                            strSql = strSql.append(" Others, NodeID, FxModeType, FxWavelength, FxDistance, BoardType, PowerSupply ) ");
                            strSql = strSql.append(" VALUES( '").append( remoteHost ).append("', '").append( sysD ).append("', '");
                            strSql = strSql.append( strFamilyName ).append( "', '" ).append( iProductType ).append( "', " );
                            strSql = strSql.append( iNoOfFxPorts ).append( ", '" ).append( strFxSignal ).append( "', '");
                            strSql = strSql.append( strFxConnectorType ).append( "', ").append( iNoOfUtpPorts ).append( ", '");
                            strSql = strSql.append( strUtpSignal ).append( "', '").append( strOthers ).append( "', ").append( iNodeID );
                            strSql = strSql.append(" , '" ).append( strFxModeType ).append("', '").append( strWavelengthType );
                            strSql = strSql.append("' , " ).append( iFxDistance ).append(" , '").append( strBoardType );
                            strSql = strSql.append("' , '" ).append( strPowerSupply );
                            strSql = strSql.append("' )" );
                            System.out.println("-sql--->"+strSql.toString());
                            dbCon.executeSql( strSql.toString() );
               } catch(Exception e3) {//e3.printStackTrace();
            } //End Of While
            if(pdu.isBroadCastEnabled()) {
               /* System.out.println("This is the response for" +
                    " a broadCast request.");
                System.out.println("Total Responses received = " +
                    (totalResponses++) + ".");*/
            } else {
                getFinished = true;
        return true;
    public void debugPrint(String debugOutput) {
        return;
