Possibility to sort posts within a request / split single posts to a different request and sort them chronologically correct
Good day,
we are using the feature of the automatic pickup of mails which then will be added to a request once a request number is in the subject. It happens quite often that we have to add the request number manually which leads to the situation that posts can be added to a request in a wrong order.
Furthermore it can happen that posts were added to the wrong ticket. For this you can split it up to a new request which then can be merged into the correct one. Here you have the same problem when you want to have this specific post at a certain position with in the request.
The solution would be to create the possibility to sort posts with a request. Additionally it would be helpful to directly split a post into a different request. This would help saving request numbers.
Please let me know your opinion.
Thanks and best regards
Manuel
