OpManager hangs ... Java engine problem? (with logfiles)
Hi All,
I'm experiencing in a boring problem with OpManager. I'm using last version, demo mode. Sometimes hangs. I check /opt/AdventNet/ME/OpManager/logs.
Last written files are:
-rw-r--r-- 1 root root 44523 Nov 12 19:17 stdout3.txt
-rw-r--r-- 1 root root 184334 Nov 12 19:19 nmserr4.txt
-rw-r--r-- 1 root root 227723 Nov 12 19:29 stderr3.txt
-rw-r--r-- 1 root root 5880810 Nov 12 19:30 alert_audit468.txt
alert_audit has no important infos.
Last lines of stderr3.txt are:
19:19:04:544 PM Data Collection is still pending for 2... 1924 key--> InterfaceInOctets emc2sp3.libero.it .1.3.6.1.2.1.2.2.1.10*8/$DELTA_TIME
19:19:04:545 PM keysVec.size() 290
19:19:04:545 PM Data Collection is still pending for 2... 1926 key--> InterfaceInUtilization emc2sp3.libero.it (.1.3.6.1.2.1.2.2.1.10*8*100)/(.1.3.6.1.2.1.2.2.1.5*$DELTA_TIME)
19:19:04:545 PM Data Collection is still pending for 2... 1923 key--> InterfaceOutOctets emc2sp3.libero.it .1.3.6.1.2.1.2.2.1.16*8/$DELTA_TIME
19:29:26:758 PM RunCmd : Error closing InputStream java.io.IOException: Bad file descriptor
Last lines of nmserr4.txt are:
at java.io.FileOutputStream.<init>(Unknown Source)
at com.adventnet.nms.eventdb.trapstore.TrapBuffer.run(TrapBuffer.java:342)
at com.adventnet.nms.eventdb.trapstore.TrapBuffer.endWriting(TrapBuffer.java:291)
at com.adventnet.nms.eventdb.trapstore.TrapBuffer.saveTrap(TrapBuffer.java:121)
at com.adventnet.nms.eventdb.trapstore.TrapFile.saveTrap(TrapFile.java:49)
at com.adventnet.nms.eventdb.trapstore.TrapStore.receivedPacket(TrapStore.java:149)
at com.adventnet.nms.eventdb.trapstore.TrapStore.run(TrapStore.java:122)
18:46:32:323 EVENT: Error while saving traps: state/traps/1698469 : java.io.FileNotFoundException: /opt/AdventNet/ME/OpManager/state/traps/1698469 (No such file or directory) at:
at java.io.FileOutputStream.open(Native Method)
19:19:21:341 EVENT: Error while saving traps: state/traps/1710929 : java.io.FileNotFoundException: /opt/AdventNet/ME/OpManager/state/traps/1710929 (No such file or directory) at:
informa:/opt/AdventNet/ME/OpManager/logs# tail -40 nmserr4.txt
18:11:39:222 EVENT: Error while saving traps: state/traps/1685999 : java.io.FileNotFoundException: /opt/AdventNet/ME/OpManager/state/traps/1685999 (No such file or directory) at:
Who can help me? Seems a bug?
Stefano
