Ongoing problems with entries NOT removed from DB
`Running OM 8007 on CentOS 5x and still have problems after trying to remove a device, and then not being able to re-add it since the software "believes" the interface already exists. These ongoing database corruption issues by many users clearly indicates an improperly designed DB. I have tried the script, RemoveDB this DOES not work. Tried to remove manually with the mysql approach listed elsewhere in these forums (mysql -u root -P 13306 OpManagerDB), but none of the suggstions work since the db clearly requires a password for mysql localhost. I think a script with ACTUALLY works to remve ALL entires is needed here until the database can be properly designed.
