Need help ! problem to restore OpManager DB
I need your help to restore our OpManager server.
After a break down with the OpManager Server, I had setting up a new server with same release (OpManager 5.5 + Service pack 6000).
I have only a ntbackup from my old server with directory OpManager.
I can restore ..\OpManager\conf directory and start again OpManager => it works
But if try to restore data (..\OpManager\MySql\Data\OpManager) , server don't start, there's an error with DB fialed.
If I restore the data directory in a other directory under ..\mysql\data, I can see and check tables with MySQLAdministrator.
Is there a possibility to check the DB ?
I try with DBrepair.bat but there's no error ?
thanks for your suggestions,
Christophe
