Manage Engine not starting
I am not able to start the Manage Engine. The OS is RedHat linux 4.
The following is the error I found in the logs.
1 Sep 2010 18:16:34:126          -------RDBMS related information------
          database product name = MySQL
          database product version=4.0.20-pro
          database driver name=MySQL-AB JDBC Driver
          database driver version=mysql-connector-java-com-3.0.15-ga ( $Date: 2004/08/09 22:15:11 $, $Revision: 1.27.2.43 $ )
          database user name=root@rd2.vepl.com
          database URL=jdbc:mysql://127.0.0.1:13331/AMDB?autoReconnect=true&useUnicode=true&characterEncoding=UTF-8
1 Sep 2010 18:16:34:534 java.sql.SQLException: General error message from server: "Can't find file: './AMDB/AM_ARGS_10000789.frm' (errno: 13)"
1 Sep 2010 18:16:34:534         at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:1990)
1 Sep 2010 18:16:34:534         at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1160)
1 Sep 2010 18:16:34:535         at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:1271)
1 Sep 2010 18:16:34:535         at com.mysql.jdbc.MysqlIO.sqlQuery(MysqlIO.java:1217)
1 Sep 2010 18:16:34:535         at com.mysql.jdbc.Connection.execSQL(Connection.java:2237)
1 Sep 2010 18:16:34:535         at com.mysql.jdbc.Connection.execSQL(Connection.java:2185)
1 Sep 2010 18:16:34:535         at com.mysql.jdbc.Statement.executeQuery(Statement.java:1156)
1 Sep 2010 18:16:34:535         at com.mysql.jdbc.DatabaseMetaData.getColumns(DatabaseMetaData.java:850)
1 Sep 2010 18:16:34:535         at com.adventnet.nms.store.relational.MetaDataInfo.getMetaDataInfo(MetaDataInfo.java:339)
1 Sep 2010 18:16:34:535         at com.adventnet.nms.store.relational.RelationalUtil.initMetaInfo(RelationalUtil.java:1251)
1 Sep 2010 18:16:34:535         at com.adventnet.nms.store.relational.RelationalUtil.initMetaInfo(RelationalUtil.java:1240)
1 Sep 2010 18:16:34:535         at com.adventnet.nms.startnms.NmsMainBE.main(NmsMainBE.java:356)
1 Sep 2010 18:16:34:535         at com.adventnet.appmanager.server.startup.Nmsstarter.main(Nmsstarter.java:129)
1 Sep 2010 18:16:34:535         at com.adventnet.appmanager.server.startup.StartServer.main(StartServer.java:815)
1 Sep 2010 18:16:34:884 java.sql.SQLException: General error message from server: "Can't find file: './AMDB/AM_SAP_Config.frm' (errno: 13)"
1 Sep 2010 18:16:34:884         at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:1990)
1 Sep 2010 18:16:34:884         at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1160)
1 Sep 2010 18:16:34:884         at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:1271)
1 Sep 2010 18:16:34:884         at com.mysql.jdbc.MysqlIO.sqlQuery(MysqlIO.java:1217)
1 Sep 2010 18:16:34:884         at com.mysql.jdbc.Connection.execSQL(Connection.java:2237)
1 Sep 2010 18:16:34:884         at com.mysql.jdbc.Connection.execSQL(Connection.java:2185)
1 Sep 2010 18:16:34:884         at com.mysql.jdbc.Statement.executeQuery(Statement.java:1156)
1 Sep 2010 18:16:34:885         at com.adventnet.appmanager.db.AMConnectionPool.executeQueryStmt(AMConnectionPool.java:128)
1 Sep 2010 18:16:34:885         at com.adventnet.appmanager.cam.AMCAMProcess.startSAPCCMS(AMCAMProcess.java:118)
1 Sep 2010 18:16:34:885         at com.adventnet.appmanager.cam.AMCAMProcess.run(AMCAMProcess.java:105)
1 Sep 2010 18:16:34:980 java.io.FileNotFoundException: ../logs/diagnostics/diagnose/diagnose8.log (Permission denied)
1 Sep 2010 18:16:34:980         at java.io.FileOutputStream.openAppend(Native Method)
1 Sep 2010 18:16:34:980         at java.io.FileOutputStream.<init>(Unknown Source)
1 Sep 2010 18:16:34:980         at java.io.FileWriter.<init>(Unknown Source)
1 Sep 2010 18:16:34:980         at com.adventnet.appmanager.util.Constants.logDiagnosticInfo(Constants.java:877)
1 Sep 2010 18:16:34:981         at com.adventnet.appmanager.server.framework.MemoryWarning.setPercentageUsageThreshold(MemoryWarning.java:68)
1 Sep 2010 18:16:34:981         at com.adventnet.appmanager.server.framework.MemoryWarning.<init>(MemoryWarning.java:34)
1 Sep 2010 18:16:34:981         at com.adventnet.appmanager.server.framework.MemoryWarning.getMemoryWarning(MemoryWarning.java:26)
1 Sep 2010 18:16:34:981         at com.adventnet.appmanager.server.framework.AMServerFramework.callMain(AMServerFramework.java:105)
1 Sep 2010 18:16:34:981         at com.adventnet.nms.util.RunProcessSmall.runCommand(RunProcessSmall.java:97)
1 Sep 2010 18:16:34:981         at com.adventnet.nms.util.RunCmd.run(RunCmd.java:100)
1 Sep 2010 18:16:47:434 ManagedObjectProvider : Unbinding Failed java.rmi.ConnectIOException: non-JRMP server at remote endpoint
1 Sep 2010 18:16:47:443 RunProcessInterface reference for the key com.adventnet.nms.topodb.DBServer is null. Can not shutdown the module with the key com.adventnet.nms.topodb.DBServer
Let me know if you need any more info. Thanks in advance.
