juniper srx3400 Interface flow problem
These days, in the use of NAF 9.8.6. We found that the juniper equipment and the flow of the actual flow gap, only the actual flow rate of 1/10, or even less. Do not know what method can solve this problem, the following is our equipment configuration.
forwarding-options {
    sampling {
        input {
            rate 100;
            run-length 9;
            max-packets-per-second 7000;
        family inet {
            output {
                flow-server 192.168.21.112 {
                    port 9996;
                    no-local-dump;
                    version 5;
