Import of switches using CSV does not work in oputils
Hello
I have been trying to import switches into Oputils using the bulk CSV file import but I had no luck
Below a sample of my csv file:
China,switch1,readonly,v1,China,,,,,,,,
China,switch2,readonly,v1,China,,,,,,,,
I'm using the format that is provided as sample in the CSV import form.
Am I doing something wrong or the import does not work?
I'm using the trial version of Oputils, build 71023
Thanks and best regards
Mark
