Extreme Switches and Switch Port Mapper
I have several Extreme Switches, Alpine 3808 and Summit 200's, and I am trying to view details using the Switch Port Mapper on any of these switches.
Looking through other forum entries I have added in the correct MIBS but when I check the Switch Port Mapper all it shows me is what ports have something plugged in or not) It does not show me what is actually plugged in which I what I am led to believe should happen.
Any ideas how to get this to show the correct data?
Not sure if it is relevant but I can't see CPU, Memory, or Backplane Utilization on any switch either although as I say above I can see all ports and whether they are in use or not?
Any help would be appreciated.
Many thanks
