Custom monitor problem
I have problems plotting the IIS current connections. I have the MIB's in place, and i am able to get the value from the MIB oid. The only problem is, it does not display me the absolute value, but the difference between two measure points. So i changed <timeavg> to false, but that does not solve the problem, it is still displaying the difference between two measure points and not the absolute value:
<CUSTOMGRAPH Name="test 222">
<YAXISTEXT></YAXISTEXT>
<DISPLAYNAME>test 222</DISPLAYNAME>
<name>test 222</name>
<oid>.1.3.6.1.2.1.11.1</oid>
<type>node</type>
<timeAvg>false</timeAvg>
<interval>300</interval>
<THRESHOLDENABLED>false</THRESHOLDENABLED>
<FAILURETHRESHOLD>1</FAILURETHRESHOLD>
</CUSTOMGRAPH>
</GRAPH-INFO>
any idea's ?
