I have opManger 8 and the cpu utilisation (cli) for linux isn't working, it appears the command line being used is not right for linux, as it returns an empty string if typed manually on the cli. When you use the test monitor button, it reports no response. The cmd line it is using is
top b n 1 | grep 'CPU[0-9* states:'
which in Fedora 12 returns an empty string, is there way of editing this monitor so that the cmdline can be altered?
