Backing up HP 6120xg blade chassis switch
I am unable to backup my HP switches.  I need "oobm" added to the end of the tftp command do that it uses the out of band interface to send the configuration.  Like so:
copy running-config tftp 2.2.2.2 filename.cfg oobm
The script currently only uses:
How can I edit the script or use an alternate backup command?
