Any way to fix sorting? Should be in alphabetical order, not ANSi code order
Capital letters are sorted first and lowercase letter and sorted later in the list.  Why is it like this?  I need it to sort alphabetically like any other program would do.  Is this something we can change in the settings somewhere?
It should sort like  A b C d E f
but instead it sorts like ACEbdf
