Advice with using Desktopcentral for Patch Management
We recently had an external audit of the machines on our network for security vulnerabilities and they found that there was a couple of updates missing on our machines, MS KB3125869 & MS KB3116180 which are covered under the MS15-124: Cumulative Security Update for Internet Explorer update. When we ran the patch scan on Desktopcentral and it didn't pick up this vulnerability. Can anyone suggest the best way we can use Desktopcentral to ensure that these types of vulnerabilities aren't missed in future or would you recommend using an additional product?
Thanks
Sean
