AD Manage Engine is Not Passing Variable to Powershell Script
I have built a script to set the Description field to read "MM/DD/YYY Disabled" once a user's account has been disabled via the Disable Policy.
The script as I have written:
SetDescriptionDisabledDate.ps1
Import-Module ActiveDirectory
param($Arg1)
$Str Get-date -Format d
Set-ADUser -Identity $Arg1 -Description "$str Disabled"
The command in the Disable Policy is as follows:
Powershell -ExecutionPolicy Unrestricted C:\ManageEngine\SetDescriptionDisabledDate.ps1 -$Arg1 %SAMAccountName%
Unfortunately, it seems that AD Manage Engine will not pass the variable to the script.
I have also tried %UserName%.
Any help getting this to work would be greatly appreciated.
Tom Gibson
